Rancho front leveling kit
CB mount/ any good ones?
Anyone Have a US Junkbox?
Has anyone used a Rancho kit to level the front of their Ram? I've got an 01 2500 4x4 with a front end replacement on it that's about 4 inches lower in the front than the rear. I called Rancho the other day and they have 2 kits for this truck, RS6576 which is coil spacers and lower links and RS6566 which is spacers, lower and upper links, and dual shock brackets. I'd like to lift the front 2 or 3 inches and was checking if anybody had any experience with the Rancho kits. Thanks.
Got'em on my 96 2500 4x4 (coil spacers and lower c. arms). Hadn't had any troubles running 35's (slight rub), but the rear may have settled a bit causing it to "nose -up" a bit. It is a gasser (360) so it's quite a bit lighter in the front. Might go with a add-a-leaf spring in the back.
2001 2500 SLT QC 4x4 ETC 5spd LWB 3. 54 Black/Agate leather. DD2's w/boost module, DD4" exhaust, ISSpro boost/pyro gauges. Custom full bumper/brush guard and headache rack, Seal-Tite tool box, B&W turnover ball.
[This message has been edited by Walker (edited 02-17-2001). ]
I had mine installed for my 99(#6476-single shock) and liked it, until I decided to get bigger tires--if your truck is a 4x4 it will allow 33" tires with no problem--if you're thinking bigger than 33" you probably would want to go to a lift kit, but for leveling the truck I don't think you'll go wrong with the Rancho kit--chris
chris sutton
1999 2500 qcab longbed 4x4 red sport w/ all the options 'cept plow pkg, 4:10 detroit locker in rear & front ARB,
5" skyjacker lift w/ 35" BFG mud terrains on 16. 5x9. 75 Weld rims, black smittybilt nerf bars, black 3 pc. bug persuader,
black lumber rack, camel leather int. w/ mb quartz spkrs and 8" sub, power edge EZ, DTT vb & tc, mag hy-tec transmission pan,
red magview diff covers & coming soon: 275 injectors, red L&L ladder bars, turbo temp monitor & guages on "A" pillar
be sure to get the right control arm bushings
Rams changed control arm bolt size on 00-01
soooooooooo doulble check for all the right sizes before installing, I had the frontend off before i realized i had the pre 00 bushing sleeves so we dont have the lower control arms yet, but the blocks are on I will put them on later
bottom line double check for exactly the right parts in the kit before you start
B... ... .....
END THE OPPRESSION FREE HVAC NOW
I called rancho on my 2001 to confirm availability and they said they needed to look at it (3-30-00) they came and took my truck for a week and brought it back fully outfitted with a 2inch lift kitand confirmed differeny bolt diam's for 01 i am running 315-75r-16's (35's) on 9. 5 inch rims had to experiment with different rims for proper backspacing to get it right had to trim fenders slightly but love the way it all works
