Rancho rs9000x
Wildcat Shift Knob
Battery condition question
Has Any one seen these yet they are 9 position adjustable.
I wanted to get 9000's and so far all my local part store's can no longer get them and most of them don't know about the new shocks.
so my truck sits and waits for new shocks which it desperately needs since mine are the factory shocks with 144,000 miles on them
rancho's
Why don't you order some from summit racing, buy three get the fourth for free. OR look up hotrodoffroad.com this is where I purchased mine for a good price. I have not heard of the 9 way adjustable just the 5 way 9000's. Well good luck.....
Can somebody explain how the Rancho cab adjustable works and how hard to install? Had not had time to check this out but sure several here have and installed. Is it worth if you have installed?:D
Rancho in cab controller
Bob I have the in cab controller. Not to hard to install I just took my time and planned out the location of my controls and pump placement. A small air compressor supplies air through small tubing to each shock. The tubing enters each shock in the location where the adjustable knob use to be. A fitting replaces this knob. I ran my tubing through black wire loom to help protect and hide, for clean install. You then have to lighted gauges for the pressure (front and back) the pressure setting match the settings on the shock. Then there is a release valve to set to desired pressure. I have had no leaks in 2 years since I installed them. Some will chime in and complain of leaks I guess this depends on how well they were installed. If I hit a section of road that is real bad I just release a little pressure to soften them up a little, then just simply refill afterwards, I guess it just makes you a little lazy. Here is a link to view a picture of my guage and control placement. My gauge lights work off my dash lights and are the same color. Scroll through and you see the picture on page 2 of post, the controls are towards the bottom .
https://www.turbodieselregister.com/forums/showthread.php?threadid=55990
If you want further info just let me know Dwayne:cool: :) :D
