Hi. I'm probably going to purchace a Raptor 100 lift pump soon based off research I've done. My current lift pump works ok but is a little low on pressure. 12 psi at idle and about 6 at wot. Been that way forever. 116,000 miles on truck LP replaced at 85000 truck runs good. Bone stock 2001 motor. Planning on 275 injectors and Edge EZ sometime. Lift lump is located in stock position near fuel filter. Can I just leave it there and bypass it with new one? I have a flatbed so in some respects I have a little more room to work. There's probably enough room to get at the tank fitting without dropping tank. I shouldn't need to do anything but hook into stock tank outlet right? And just leave old return line alone? No draw straw or anything else needed right?
