Here is a bit better version than came with my rasp
RASP Install Recommendations
Thanks go out to Bill and Stefan Kondolay and Olee Poole for their time in answering my questions about this install. They saved me who knows how much time. As well as whoever wrote the original install directions to which I have just added to here.
First inventory all your parts and make sure you have everything you need. Make sure and read the directions before you start.
The obligatory remove the battery cables.
With serpentine belt still hooked up break loose and remove the four 15mm bolts attaching the harmonic balancer. If an air ratchet isn’t being used, a breaker bar with a hammer will work. Or put a wrench on the alternator pulley to keep the harmonic balancer from turning while removing and reinstalling the bolts.
Install the drive hub assembly on to the harmonic balancer reusing the stock bolts. Torque the bolts down to 92ft lbs (per 2001 service manual). I also used a small bit of Loctite on the bolts. Make sure there is a gap of ¼”. Place the small pulley on the drive hub assembly. Do Not tighten the setscrews. My small pulley had two setscrew holes with no setscrews in them. Come to find out Bill drilled and tapped the pulley cog so that you could actually get to the set screws to tighten them down once installed. Great thinking on his part, otherwise it will be a real pain to tighten them. He had drilled and tapped one hole with two setscrews in it. The second being a lock for the first one. Worked out great.
Remove the four front center oil pan bolts. Mount the RASP mounting plate using the four supplied bolts. They are 6mm hex key and torque to 18ft lbs (per 2001 service manual). I dabbed some black silicone sealant on them to prevent an oil pan leak. Since you are there you might as well check the rest of the oil pan bolts mine were all a bit loose by a couple ft lbs. Next mount the pump assembly and slider plate to the mounting bracket. Do not tighten the slider bolts just yet. Install the pulley but do not tighten the setscrews yet. Install the belt. Spin the pulleys by hand a bit with the belt so that they will line up correctly. Tighten the setscrews on both pulleys. Remove the belt.
For the plumbing I used Olee Poole’s premade kit (
www.powerbypoole.com). It came pretty much all assembled in a few different pieces. Return line to tank, vp44/to filter housing and fuel supply line and then everything else from the lift pump to the filter housing. Not really anyway to put it on wrong as it will only go one way. If you are using his kit and use his pictures you cant go wrong. However there are a couple of check valves that look the same but are different. The valves come with the RASP pump not the plumbing kit
They are labeled as “ONEWAY” and “REG”. The ONE WAY goes between the lift pump and the fuel filter housing. If you look in one end you will see nothing but an empty space. If you look in the other end you will see what looks to be a small valve. The small valve goes towards the lift pump and away from the filter. If using Olee's plumbing kit the rubber orings are not needed due to the type of fittings he uses. The other valve labeled REG goes to the new return line back to the tank. The end with the small valve inside it goes away from the tank. I plumbed my return into the tank vent line but you could certainly do it another way. Tap into the fill tube by welding a bung or fitting on it. You could do the same to the vent line angling it down towards the tank to prevent any issues when filling up while the truck is running or drill another hole in the top of the tank and go that route. (Additional notes: First the check valves cannot have any debris in them at all. It may keep them from closing properly. So it may be wise to keep them in a plastic bag or something and take care to keep any particles out of them until it is time to install them to lessen the chance of a piece of dirt getting in them. Next, tapping into the tank vent line for the return. Some other pumps have caused issues when filling with fuel while running the truck. According to Bill K if installed properly there should be none to very little fuel coming through the return line at idle so it may not be near the issue as it is with some of the other electric pumps plumbed into the vent tube. However I have not had a chance to verify as I don’t normally fill while running nor have I had to fill up since the install. Lastly my check valves had the names written in magic marker on them. Be aware that the marking rubs off easily especially once your hands have a coating of diesel on them and they could easily be completely wiped off and mixed up. Shouldn’t be a real issue but if you are playing with them before they are installed beware).
Once the RASP pump has been installed the driver’s side port is the fuel intake line. It is recommended to use a T-fitting on the supply side to the existing electric fuel pump. When installing the fittings on the RASP pump itself I used some Teflon type pipe dope that was rated for diesel fuel.
On the outlet of the electric pump install the 4psi check valve labeled as “ONE WAY” with the valve side of the fitting being closest to the pump and away from the filter housing. This will prevent fuel from returning through the electric pump.
Route a pressure fuel line to the fuel filter inlet. It is recommended to use a T-fitting with a 1/8 npt port in it at the inlet to the fuel filter. Attach an 18” grease gun hose to that fitting. And on the other end of the grease gun hose attach the Hobbs pressure switch. Again I used Teflon type pipe dope on the Hobbs fitting. The Hobbs switch is to reduce use of the electric pump when the RASP is providing pressure. (Please take note that the RASP does not need the electric fuel pump to start the truck. It is so you have a parallel system. And to make priming the system easier when doing a fuel filter change or opening it up for any other reason as well).
Connect a separate terminal/wire to each side of the pressure switch. Route these wires to the fuel pump wiring. Cut one of the electric pump wires. Crimp or solder a splice on each end of the cut wire that goes to the pressure switch. (Here again Olee Poole came to my aid and sold me a harness that he built utilizing factory type connectors. So I did not have to splice into the stock fuel pump wiring. I just unplugged it and plugged his in. I was really not looking forward to trying to splice wires in the stock lift pump circuit, as it is tight and hard to get at. I could not find the stock type connectors anywhere but noticed in Olee’s picture that he did. So I called him and he said he had sourced some.
It is also recommended to put a lighted override switch in the cab with each side of the switch that is electrically hooked up to each terminal of the pressure switch. This allows for overriding the pressure switch for continuous operation for times like initially priming the system, changing fuel filters and in case of a broken belt. This lighted switch also gives indication of when the electric pump is running
On the outlet side of the fuel filter install a T-fitting with one port going to the injection pump and the other going to the 12psi check valve labeled “REG” or “Regulator” with the inside valve being away from the tank. From the end of that check valve route a fuel return line to the tank. The most common return is installed in the fuel vent hose with a “T “ that is ¾” inline and a 5/16” (or whatever size fuel line you are using) that goes to the return line from the pressure regulator.
Somewhere in there I would also add a T-fitting with a 1/8npt port and install a fuel pressure gauge . I put mine between the fuel filter and the VP/44. (One thing I noticed right away was changing the filter to vp44 line to 3/8” rubber and with my existing gauge setup my VP44 pulsations to my sender do not seem to be there any more at all)
Make sure all bolts and connections are tight and pulleys and belts are aligned. However do not install the belt quite yet.
To Be continued
