Stefan eluded to this a couple of weeks ago, that someone there (DTT) was working on a new RASP pump system.
I got one of the orgionals, had a little weeping at the front seal after 3 years or so. DTT sent me a new seal kit, did not stop the weeping. Then they sent me a redesigned RASP pump. The redesign had a much longer bearing housing at the pulley shaft end so a more complete packing could be installed. It looked like the same external gear cut and shafts, just a longer packing box.
IF DTT does not come up with a updated system I can make copies of about a year of research of internal and external pumps volumes, pressures, viscosity capability, manufacturer. There are some external gear pumps that would make a really good replacement.
The biggest problem I was finding was a drive system. I think you could use the Boss Pump drive (which is sort of a takeoff of the first design of the RASP pump) and the component parts are available from GDP. The ratio of crankshaft to pump shaft speed is 3:1 for the RASP.
I researched a fractional hp (1/7 hp) dc motor with something like 100,000 hours MTBF. Totally field rebuildable in about an hour, brushes changable from external access, totally sealed bearings, self cooling, harsh environment rated. I was going to direct couple the motor and pump and put a PWM (made by the motor manufacturer) on it to get 1000 shaft speed which was the optimum efficient speed of the pump.
The whole thing was going to be about $300 and should be good for 3,000,000 miles. I wanted something that would easily outlast the truck, i. e. NEVER visit the lp thing ever again.
I did not put the system together. It was fairly long (~ 24"), fairly heavy (~10 #). I have an Industrial Engineer inlaw and he thought probably 200,000 hours MTBF for the motor and never change the pump as it could pump molten lead, it is that tough. Pumping diesel fuel would be no effort at all.
Finding a pump that will do 60 GPH (bypassable to match the VP44 input) at 14 psi is sort of tricky. Many pumps have much higher pressure, much higher GPH. It's acutally is a pretty small pump.
It will be interesting to see what DTT comes up with. I have always been real happy with their products and service. I think you can bet it will be a good pump system.
NOTE: I even put a dynamic balancer on my 02' with the RASP gilmer belt system. Very tight, very close tolerances, but do able. Ads say it can not be done, it can be very carefully.
Bob Weis
