Rattle from passenger side dash only when brake pedal pressed
My '06 3500 is flashing and going into 4WLO without switching
turned back odometer?
I have a very loud rattle coming from the passenger dash/firewall area. It only occurs on hot days and when the brake pedal is depressed. Soon as I let off pedal it goes away or if I shift trans to neutral. It drives me crazy sitting in traffic or at a stop light.
If you can reproduce the noise that easily,have an assistant track down the source while you are creating it.
Tried that already... I think it is coming from under the hood... just can't tell because of the engine noise. I even had the dealer look at it. The mechanic wrote it up as "unplugged 12v splitter plug in outlet and noise stopped. " Got truck back and 2 days later without the splitter plugged still rattling. I guess my next plan is to let the rattle start and just drive straight to the dealer.
