Rattle while in gear and stopped
NV5600 Notchy shifting and brass in the oil?
Transmission clunk
I have developed a rattle when stopped in gear with engine running, sounds like pipes or something rattling (metal to metal). I have crawled under the truck while doing this and can not find the rattle by holding the exhaust etc. Any suggestions :confused: . Yes I am thinging about taking it in to the Dealer. :rolleyes:
Check to see if your transmission dipstick tube is rattling against anything.
My truck came from the dealer with a ty-wrap holding it to a metal heater line and I've never heard it rattle.
Bob
Sounds like what my truck has been doing for quite sometime. Its from a
injector that is nearing the "out-of-spec" and not closing all the way
(probably). Are you hearing a very noticable metalic tick that changes alittle
while running? Sometimes it does it louder than others.
These injectors are like spark-plugs in my opinion some will last longer than
others... A solenoid A-top an Injector is only good for so long... i was really
peaved when i found out that the injectors were electricly fired, and atleast
2 times per piston stroke...
Oh well, ill keep her untill the 100,000 mark comes around (Warranty Ends)
Wouldnt want to absorb an entire engine meltdown, or close to it, because a
injector wants to stay open and do what you see in ceamans Thread.
-Mitch :D Still lovin tha truck
P. S. If my truck was or gets any louder than it is, i would take it to the
dealer and make them do the Inj. shutdown test. So, yes i say take it to the
dealer.
