I didn't like the RAZ (cassette-CD) radio I had in the 2004 Dodge Ram, so I purchased a RBQ (6-CD, tuner) radio. When I swapped out the radio, the new radio has no volume at all. I have the Laramie package with the separate amplifier. The old radio (when swapped back in) works fine. On the 2004 Dodge Ram, the radio and amplifier are controlled by the computer. There are only two sets of speaker wires going out of the radio, yet the fade control works fine. Some computer picks up the signals on a PCI bus and then tells the amplifier to do its thing. For some reason, the computer is NOT telling the amplifier to turn on. There is no direct wire between the radio and amplifier for "turn on".
Anyone have a clue what needs to be done. My thought on the 2004. 5 is that the computer thinks there is a RAZ installed and not a RBQ radio, so it refuses to cooperate. Perhaps the computer needs reprogramming from the dealer.
I am sure that I have the correct model number for the 2004 year RBQ radio and the dealer says it should work "out of the box".
Any help/guidance is appreciated. Thanks!
