JWChessell
My RB4 Nav Radio was working perfectly until Monday, May 28th. I took out the nav CD and played two music CDs. About 4 days later I put the nav CD back in, and started to experience problems.
A msg appeared: "Resetting the system for navigation. " But shortly thereafter, another msg appeared: "Reading error. Please eject and check disc. " The instruction manual suggested cleaning the disc and allowing the radio to reset in an open area with unobstructed view to the sky, both of which I did. No improvement.
Sometimes the nav system will operate and display the MAP screen correctly. However, it will not display the ROUTE or DESTINATION screens. The "Eject and check CD" error message always appears.
Usually, when a destination is input into the system, the CALCULATING bar will move across the bottom of the screen, but then it freezes and shortly thereafter the error message appears.
Occasionally it seems that the CALCULATIONS are completed and the ROUTE or DESTINATION screens are operating correctly, and the voice prompts are working correctly, because of what can be seen happening on the screen around the edges, in the area not covered by the error message. But the error message can't be eliminated, and since the majority of the screen can't be seen, the system is useless.
It seems that the nav unit has not reset properly since I played the music CDs on May 28th. Is it the nav unit itself? Is it the disc? Any way I can try another disc without buying one?
Any suggestions gratefully accepted.
Thanks.
Thanks.
