After reading all of the letters in this forum about gutting the "cat", I thought I was ready to give it a try on my '96 4w/d std cab with 55k miles. I soaked all of the clamps overnight with Liquid Wrench and began at 8:00 AM. After loosening all of the clamps, I began trying to remove the cat. Ha! After two hours of hammering, twisting and cussing,(my neighbors used to like me) I was no closer to getting the cat loose than I was when I started. It would not move forward, backward or twist. I finally discovered that all of the female pipes had slots in them, and all of the male pipes had tabs welded to them which slid into the slots. Of course these little items are on top of the pipes and not visible. You have to start dis-assembly from the tailpipe forward. This is when I discovered that Godzilla at the factory had crimped the muffler/tailpipe joint with the clamp. In order to remove the muffler and tailpipe as a unit, I jury-rigged hangers out of rope, then unbolted the real hangers from the frame. After much pulling on the tailpipe from the back bumper, the muffler seperated from the rear of the cat. I was on my way. Gutting the cat was relatively easy. Getting everything back together by myself was not. Of course by now it's 4:00 pm, my 60 year old body has been lying on the damp concrete for many hours, my neighbors wont talk to me, and my driveway is covered with soot and broken ceramic. I would suggest checking for these slots and tabs berore starting any of this work and if present, have someone there to help with the pushing and pulling. By the way, the results were well worth the effort. There is a definite increase in power, especially in the higher gears. (5 spd transmission)
