Re-Torquing Stock Head Bolts
Quick Smarty question.
'04.5 Laying down bad
I've heard you can re-torque the stock head bolts a little to help keep the head gasket in place. I plan on doing studs in the future, but figured since the valve cover and exhaust rockers are off I might as well give this a try. Has anyone here done this or know the correct procedure and torque numbers?
Here's the 2006 procedure:
1. Torque to 52 ft*lb.
2. Back off 360° in sequence.
3. Torque to 77 ft*lb.
4. Re-check all bolts to ensure they're at 77 ft*lb.
5. Tighten all bolts an additional 90°.
I wouldn't touch them.
Ryan
Ryan
LOL so whats the real torque number
Ryan
This means they are "torque-to-yield" bolts, and Ryan is correct, probably best left alone. By following that torque sequence and then going an additional 90' that is, to put it crudely, pre-stretching the bolts a controlled amount.
That's all torquing is.
True enough, but when you finish by turning the bolt a prescribed number of degrees rather than to a particular torque specification, there is a difference.
Note also that torque-to-yield bolts are not to be reused.
True, however, the service manual does specify a bolt length and allows reuse of an old bolt as long as it's not any longer than the specification.
So I think they are "torque to almost yield".
Ryan
Ryan
As soon as a bolt stretches it has "yielded", they are just making sure it has not yielded to deformation.
Some have great results with this. . I blew a head gasket with studs. . I then had Garmon build me a lower compression motor, and he used bolts instead of studs. . I didn't get much runtime on the truck, but the new owner said it blew the head gasket just a couple days after he had it. . I was gonna do bolts on my 06 until this happened. I changed my mind, and just went with studs. . I don't plan on pushing mine past 50 or 55 pounds anyway. .
