Readers rigs management
Test Post
Pictures Question
Is there a way to change the order in which pictures are layed out in an album? i just deleteed some and added others and they seem to be in a random order.
I am also posting a pict as a test.
Thanks
Ted
Why wont this show up as a pict as it always does for me. All i am getting is a url???????????:( :( :( :(
I believe to save bandwith, the TDR setup the boards to only display an image from areas other than thier site. So lets say that a pic was listed on Yahoo, it would show up. But it won't show if it's from the readers rigs.
I think. :confused:
I think the only other way to change the order is to delete the photos and start over.
In order to link to pictures on the readers rigs section you need to use html code instead of vbulletin code. That's because vBulletin won't parse PHP which is required to display pictures from the readers rigs section. Click on edit at the bottom of this post and you'll see how you need to code it for it to display:
I'll look into if it's possible to rearrange the pictures in the user gallery - I'm not sure.
img src="https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=1858&.jpg"
that bracketed by <>
is that right steve?
Steve did you just change code in teh reader rigs forum?? I got the forums code for this pict and it was already in the correct html format. The last one was not.
<img src=https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=1857">
Yeah, that's right. I just looked and there isn't a way to reorder your pictures. BTW, I also just modified the reader's rigs code so that if you go to any picture you can click on the link at the bottom that says "Forum Codes" and it will show you the exact text you need to put into a message for that picture to appear, you can cut and paste it from there if you like.
