ready lift, good or not?
Replace CAT "Test Pipe" w/Muffler or Resonator
Towing connector power circuit dead
Planning to lift my truck and I'm leaning towards the Ready Lift since this lift kit is on sale at 4wo (click here for their lift products). I used the search function but didn't find the info I need. Does anyone have this kind of lift? I'm planning to get the kit that includes 3" lift coil spacers plus 1" rear blocks. Is this enough to fit 35" tire size? Any opinions or suggestions? Thanks.
Opinion? Forget the pucks and do a suspension system with VR springs, then you have something. The pucks just push it closer to DW and mess up the steering geometry which accelerates the wear of marginal steering pieces. To do it right requires adjustable track bar and adjustable control arms or the axle is off centered and moved back too far driving the tire into the ground more. The pucks work, just not as well as a real suspension system. They will allow clearing a 35" tire but it will still rub on the control arms at full lock with stock wheels.
You can fit 35" tires with no lift on stock wheels, I would never do a spacer over 2", as far as spacers go there pretty much all the same, but ultimately Cerberusiam nailed it!
