Real time data
Drove into work this afternoon with the Diablo as a diagnostic tool just messing around.
Picked out the HPCRpressure mode and watched as I drove.
In park at idle, I was seeing 46. 00Mpa-48. 00Mpa which I believe is 4600-4800psi.
In gear at idle, pressure was bouncing around between 5300-5700psi.
I wasn't able to go full throttle at all, nor build more than 10lbs of boost due to traffic conditions.
I did see the highest pressure in the 14,000psi range but most cruising speeds of 35-45mph and it was reading between 9500-12000psi.
I'm going to keep a log to see what highest pressures I see, what average cruise pressures at certain mph's, etc. .
Then, when I re-install Quads XZT (after they change the tune), I'm going to see if it'll read any changes.
There is alot of cool stuff to monitor with this programmer.
