My 2001 HO 6 speed became really hard to start hot or cold around the first of November. It did the same thing last year. If the truck sits for about 30 minutes or more, it starts only after a long cranking period or a long run of the lift pump. The problem seems to appear with the arrival of winter blend fuel at the pump.
The Cummins TSB 18-015 that was applicable to my engine addressed this problem with a reflash of the ECM to reduce voltage to the lift pump to prevent cavitation (bubbles in the pump output due to overpumping action) of the winter blend fuel. The Cummins hot line said the reflash would do the trick.
It did not help. The truck is still just as hard to start. It resembles an out of fuel situation inside the VP44 which is only overcome by the lift pump running for a long time and priming fuel tthru the VP44.
There is no evidence of fuel leaking anywhere either running or stopped.
I posted an earlier similar thread, but now that I know the reflash did not fix anything, here I am again.
Anyone have any suggestions?
Thanks,
Harry
Thanks,
Harry
