JR,
Thanks, Sorry, I had a bit of a hard time driving out the front bearing, I was expecting the same with the back. I was taking a break thinking I couldn't get at it with our bending the fins, the puller I have is just a little big, either leave the old one on or cut it off. I thought screw it, I'll just cut it off. I went out in the garage I have nothing to loose, had some small pry bars, that kind of fit. The bearing popped right off. I should have tried that first instead of worrying about. Other than the issue with the front bearing it was one of the easiest things I have done. I replaced the fuel injector pump and the in tank fuel pump last summer.
The video I was watching shows after the front bearing being removed, a bearing being cut off. Upon a closer look it is the front being cut off. The video never shows the rear bearing being removed.
