Rear Axel Seals Leaking ... Advice
Track Bar
Tailgate Oops... How should I fix it?
Truck has 180k miles, and I plan on driving it to 350k miles. Diff oil has been changed with synthetic every 50k miles.
I had smoke coming out of my passenger rear wheel. I thought I had a caliper that was hanging up, so I got a new caliper, pads, and a rotor and sat down to do the work.
When I took the rotor off, I found moisture (smelled like gear oil) inside the rotor hat (parking brake area). I must have a bad outer seal.
Because of pulling out / pressing in new bearings I think I am going to have a local axle shop do the work. Here is what I plan on asking them to do:
-Replace inner and outer seals right and left
-Replace axle bearings
-Change diff oil
-Check diff for wear
-Turn rotors
-New pads
-New parking brake shoes
In the past 50k miles, the front hubs, front outer u joints, front drive shaft, and rear drive shaft have all been replaced or rebuilt with new parts.
I can't think of anything else to do while the axle is being worked on. Given my plan to drive this truck another four years, is there anything else I should be doing to increase durability / reliability while the truck is being worked on?
Thanks,
Bernie
Then why are the bearings packed in grease and why is there a grease seal for the bearings?
To give the gear oil time to get to the bearings... if your logic held true, why do they leak gear oil when they fail? :rolleyes: When was the last one you took apart that had ANY grease in it after any amount of miles??
I fell off the turnip truck last week...
This is my first go around with a full floating design. Learn something new all the time. My last rear end tear down was on a 85 4 Runner. It had sealed bearings with a seal to keep the diff fluid in.
They aren't packed, they run in the same oil as the diff. There is only one seal on each side and it's a two piece seal. The inside half is stationary and the outside half rotates with the hub. They're spendy seals and a little tricky to get back together right. Be sure you hold the hub straight/square when you slip it on.
I would inspect the bearings, they likely do not need replaced. Service the brakes as required and replace the seals.
-Scott
I repaved one last weekend. No biggie... . just be sure and have a 6 point hub nut socket. The seal will pry off with a screwdriver and your bearings are likely in very good shape. Be sure to use a little wheel bearing grease on reassembly, both in the bearings and a light film on the axle to keep u from messing up the new seal.
