I have a 1998 Ram, 12 valve extended cab long bed auto, 3. 54 axle which has just been involved in a side swipe accident when my son was driving it. A car drove into the side of the truck at speed. The rear axle has been shifted one eigth of an inch to the driver's side, and may need to be replaced if changing the brackets does not cure the misalignment. I would be grateful for advice on any issues I should consider if a new rear axle is required. In particular, should I opt for disc brakes at the rear instead of the present drums, and would a different rear axle ratio, perhaps 4. 10 be better for my intended use? I will use it for flat trips unlaoded between Maryland and Florida, but I also want to pull my 25ft Airstream travel trailer (6500 lbs, 800 lb tongue weight) on future dream trips over the Rockies and throughout the USA. (I plan on fitting a BD exhaust brake and Autoloc before doing so). Any advice would be gratefully received. Thanks, from Nick.
