George 00, the dana80 will bolt up, but the driveline will need to be cut down 1 3/4 inches or so, the brakeline junction may need to be swapped with your old dana 70, custom or longer u-bolts, 2nd gen u-bolt mounting pads(you will need to find another way to mount your shocks, the 80 uses a staggered system while the old 70 mounts both shocks behind the axle in an A style), reconfigured parking brake cables and rim modifications. Is your truck a single wheel or a dually? Mine is a dually. I had to grind off the centering or pilot rings off the stock rims to get them to seat to the axle hub flange. The center hole in the rim fits perfect on the 80 hub. On first gen duallies, the rims are stud piloted, they are hub piloted on the second gen duallies. I hope this helps some. The u-bolt/shock mounting pad on your first gen won't work with the second gen axle, as in my case. Good luck! Noel
