Engine/Transmission (1998.5 - 2002) Rear Axle Hub Nut Size
Engine/Transmission (1998.5 - 2002) Comp Disconnect Problems
I have a 98. 5, 2500, 24V, 5sp, Reg Cab 4x4.
The last few days the rear brakes have been 'grabbing', I have 98,000 mi on the truck so I figure it's the rear axle seals.
Can someone tell me what size socket I must have to get the hubs off? I checked the local parts house, they have to order the proper size but they don't have any application guide, you have to know the size you need. I could rip an axle out and try to measure the thing somehow, but I'd really rather not. Besides I'd rather find out for sure the proper size rather than trying to measure and ending up ordering the wrong one. If someone has a 'Lisle' or 'OTC' part number that would be super cool. By the way I have the Dana 80 rearend.
Thanks
Most wheel seals I have had fail...
have been from the bearing being too loose. After you take the axle out, before loosening the nut, check the "play" in the bearings just for fun!!!
