I would like to change the rear end ratio in my truck from 4. 10 to 3. 54. I located a '97 Dodge Maxi Taxi ( I believe it's a one ton) Ram Van in the salvage yard today. The hood was missing so I couldn't find the equipment list. I couldn't find a data tag on the differential cover, but I found a tag on it that said to use limited slip differrential lube. It has 8 lug bolts & it is's of the design where you can pull the axle shafts without disturbing the wheels. The drums were exposed so I slipped one off-looked like 3"wide brake shoes to me. It has the ABS sensor on top, just like mine. It sure looks a lot like what I have on my truck - could it be a Dana 70? Are the single rear wheel axles the same width between brake backing plates as the dual rear wheel axles? If this could be swapped out it would only run me $70 for the axle drum to drum! Even if it were another 4. 10, it would be nice to have one on the bench while swapping out the gearset, leaving my truck on the road while I learned how to "set one up". But if the backing plates are farther apart than on a dually, well then it's not a whole lot of help.
I appreciate your insight & your time. Thanks for the help!
Joe Jump
St Louis
Joe Jump
St Louis
