Rear axle leak
Voltage Problems
CV Half Shaft removal
I have a Dodge 1997 3500 dually. I recently discovered 4 loose bolts on the rear axle hub passenger side all others are tight. lost some oil. Need to know if the seal could be damaged and what may have caused these bolts to come loose, also what torque they should be tightened. Thanks
