Just did one in my 99 and there were no problems! I got a complete rear, with the parking brake cables, off a long bed QC truck. I bolted it into my shortbed 99 QC and everything fit as expected. I did have to reflare the brake lines into the junction box on the axle housing, because I used the brake hose and junction block for the 99, and the 2001. 5 hard lines have bigger fittings. This wasn't a problem because I expected it, and . 90 cents worth of brake fittings and my double-flaring kit took care of it quickly.
The brake cables went right back on like the 99's, although they had less play in them, so I had to loosen the brake cable adjuster to get both cables connected.
Once I got the brake lines connected I opened the farthest bleeder screw and let the brakes gravity bleed while I messed with brake cables and such. Went over without a hitch.
Easiest rear swap/conversion I ever did. I'm looking for one for my 96 now.
Chris
