2nd Gen Non-Engine/Transmission Rear Axle Wrap
Looking for some knowledge on this. How bad a problem is axle wrap? I just put on the Skyjacker D25 coils and the front is ~. 5 taller than rear. Skyjacker has 2 solutions. 1. ) Add a leaf and 2. ) Complete Springs, such that you replace the block. Which they say will eliminate/reduce axle wrap Number 2 is quite a bit more expensive.
thanks
I think Steve St. Laurent has the best solution. Ladder bars. My axle wrap is horrible in the sand. I will be doing ladders soon.
Is the problem with the ladder bars fixed? I understand the frame was cracking where the bars attached? I would like to add ladder bars to stop axle wrap when backing my heavy fifth wheel.
