2nd Gen Non-Engine/Transmission Rear Brake caliper adapter bolt torque ??
Engine/Transmission (1994 - 1998) What Next?
Engine/Transmission (1998.5 - 2002) VP44 check valve
:confused: Hi everyone,
Replacing rotors, calipers, and pads on rear brakes of my 2002 . The manual talks about torqueing the front caliper adapter bolts to 210 ft. lbs. , but doesn't mention anything about the two big rear caliper adaptor bolts.
Even 210 sounds way too much if this refers to the rear also
Does anyone know the proper torque of these. . (Rear Caliper Adaptor Bolts) ??
I know the two small caliper bolts are 24 ft. lbs. ,, and the brakeline banjo bolt is 30 ft. lbs.
I don't want to twist them off !!
Thanks in advance for a quick reply !!!
