B.G. Smith
Did the rear pads on truck yesterday. The drivers side top caliper bolt was so close to the rear spring the after I had loosened it a few turns I had to finish removing with an open end wrench,(not enough clearance to use box end or socket). On the passenger side the top bolt was even higher, not enough room between the caliper and spring to remove bolt. I had to remove the top caliper cupport bolt and loosen the lower bolt and tilt the caliper out to temove the top bolt. Is this about normal bg
