I just changed my front brakes (70k miles) and the rear brakes are really sensitive. They've always been sensitive but it's extreme now, at 15 mph just a light step on the pedal will lock them up for a couple feet (abs does work at higher speeds). I have to be real light on the pedal. Also, they will stick on a little at low speeds. Only thing I can think of is that a couple months ago I boiled the brake fluid on a down hill while towing, a bunch of smoke came out of the rear wheel wells and I had to add a bunch of brake fluid to get the brakes working properly again. I have inspected the brakes, I can't see anything abnormal. They are adjusted properly. Is it possible that the boiling brake fluid coming out of the pistons could have gummed them up or something?
