Rear Diff-Can't Stop Leak-Leak Found-Right Through The Casting
Its been a long time, my truck has just been that good.
Anyhow, if anyone has any suggestions re: the following condition, I sure would appreciate it. It is driving me crazy.
2005 w/ 11.5 rear
Couple month ago, drips from rear end on driveway.
I needed to change the fluid anyway. So I pull the factory cover and replace the fluid and torque to forum relayed specs. I cleaned both matting surfaces and removed the "cancer" from the rear end housing (like an 1/8" to 1/4" of the exterior of the housing is flaking off). I reused the gasket.
1 week later, drips. I remove the cover, save the fluid, buy new "re-useable" gasket and put all back together using proper torque.
1 week later, drips. I re-torque all the cover bolts to higher than recommended on this forum, but not so much to snap them off.
1 week later, drips. I order a mag-hytech. It comes in, I drain, install mag-hytech.
1 week later, drips. What in the heck is going on? The mating surface on the rear end not planed properly? Perhaps that outer 1/4" of housing was holding the fluid back and the "inner" metal is not machined properly? I don't know.
Losing all that metal off the rear end worried me a bit. Should I try re-torqueing the mag-hytech bolts to a higher amount, or drop the fluid, pull the cover, ditch the o-ring and rtv the cover on with a good amount of bead?
It has really ticked me off. Any help would be appreciated.
2005 w/ 11.5 rear
