Engine/Transmission (1998.5 - 2002) Rear Differential help needed
2nd Gen Non-Engine/Transmission Loose weather strip & thermal pad
2nd Gen Non-Engine/Transmission Door Handle Repairs
Yesterday morning I was pulling onto a main highway, and had to apply added right foot pressure to fall in line with traffic. I was also pulling a 6,000 lb. load at the time. During this time I sensed something was either broken or just let go in the rear differential. Shortly after, I started hearing a growling noise that would come and go under differing conditions. Sometimes I would hear it during acceleration, sometimes going around a bend in the road, and sometimes when I hit a rough spot in the road. By the time I got back home later last night, the only time it was evident was under low speed acceleration. I suspect carrier bearing, but maybe pinion bearing. I would imagine this kind of thing has happened to others, so if you have any thoughts on this one, please share them. BTW there are no leaks anywhere. Thanks in advance.
Take the cover off and look for carnage.
The LSD Dana 70/80 likes to eat spider gears from the clutch packs not slipping the way they should, or from abuse due to overloading.
They also eat carrier bearings... .
Both of these things are easy to change... but time consuming... . and will make all kinds of different noises under varying conditions.
HTH,
Matt
I had a similar noise on my truck. Pulled the diff. cover and was shocked to see 4 teeth broken off the ring gear. Chunks of metal in the diff. I hope yours has not grenaded like this. I lucked out and got it repaired under my extended warranty even with all my mods and lift. This wasn't even the dealer I bought the truck from. Good luck. -Glen
