The drums are a separate mechanism from the disc brakes. Follow the e-brake cable to the dust covers on the back of the hubs. Behind that cover are the e-brake shoes, and they're just a small version of normal drum brakes. The adjuster will be behind a rubber plug on the opposite side of the axle that the cable enters (i. e. the cable goes in top, plug is on the bottom - opposite for the other side). Pop the plug and you'll find the starwheel. Flip the starwheel until you feel the wheel start to drag as you spin it (a flat blade screwdriver will work), and then back it off slightly.
