I'm looking to convert to rear discs. I ran search on "rear disc" and came across a thought. The cost for a conversion boggles me when all your talking about are all OEM parts. I read a thread from ERIC12,and he stated the calipers are from a 1977 Olds Toronado,thats 33% of the equation,all you need to find out is where the rotor comes from. Then order a WHITEY part # SS-83KFT2,which is nothing more than an inline ball valve good for 6000 psi or use a standard line lock. Then go down in the basement,machine a bracket, flare your own lines,and your ready to boogie.
---OR---
What are the differences between a 2001. 5 and later factory disc-equipped axle and a 1999 axle,are the spring center pins the same width from spring perch to spring perch?Would'nt it be faster and cheaper to drop the old rear out and slap a newer disc equiped rear in? Please correct me if im wrong or let us know where to order the rear rotor. Thanx
---OR---
