Well it stopped raining for a while today i was able to get started on my EGR rear disk conversion, everything came apart real easy and all the EGR parts fit well, the only problem i ran into was the banjo bolt on the brake line where it connects to the caliper hit the inner bracket and i had to grind a little notch for it to clear, this would not be a problem on truck that only require one spacer between brackets, i was about 30 min from finishing mounting all the new parts and i had a run in with a cut off wheel on a die grinder (i was notching the second bracket) and cut a vessel, nerve and tendon on my ring finger, so off to the emergency room i went, a bunch of scrubbing and 4 stitches later i'm back home and should be able to finish tomorrow if the weather holds(raining again now) all in all an fairly easy conversion, i think the worst part will be changing0 all the other brake lines (front and back) to the new EGR lines,
Here is a link to some pics of todays work
Conversion Pics
Rick D
Conversion Pics
Rick D
