check this out
I've got 51,000 miles on my truck and took it in for warm or no air on the passenger side and a rear drive shaft that sounds like it's just rolling around in the carrier when coming to a stop.
A little history:
-rear driveshaft completely replaced last fall for the same, except it shuddered under power then as well as stopping
-direction doors worked on twice for heat/defrost
-alternator bracket replaced
This service department has always been very good to me. I'd drop the truck off in the morning with a few complaints, they'd call in the afternoon and tell me I could pick my truck up and they'd order parts. In a day or 2 they'd call, say the parts were in, I'd drop it off the next morning and that afternoon, they'd call saying it was done. Pretty seamless and smooth I thought.
back to the story ... ... .
So I take it in on Monday for the driveshaft vibration and air problem thinking all is gonna be fine. I was told that morning that there was a TSB on carrier location and it needed shiftet to the passenger side.
I get a call that afternoon quoting a $4,000. 00 fix from some new service writer whom I've only briefly met that morning. I just laughed :-laf
It appears that the freon is 1/4 lb low, needs emptied and recharged with dye and the ATC or ATS or something needs reprogrammed for $300 or $400 something... .
1 u-joint in the front axle needs replaced
both front wheel bearings need replaced, at $400 something a side
all u-joints in the rear driveshaft need replaced
both diffs need flushed and filled because the rear is 1/2" low, $290 something
tires need replaced, $1800 and change
carrier needs realigned, $45
now I'm really laughing :-laf
I said "I've got 70,000 on drivetrain, you've already worked on the drivetrain and climate control and I can get the tires for $800 less.
Well, he called me back. got it down to 590 something.
Air not covered because it is now a freon/program problem and not mode doors. Which still baffles me cause it works fine on the drivers side.
Alignment of the carrier not covered because ... ... ... . well just because, lol. 70,000 mile protection and TSB, still not covered. I said cool, I'll get a whole new drive shaft next spring cause I only want the warranted work done.
I'm going on a big trip loaded next month, so I'll change the oil and diff fluids myself. A tech told me what the TSB on the carrier was all about, I'll do that. And, I'm holding out on tires as long as I can before this trip and winter! (I'm always find myself having new tires in spring and junk through the winter, not this winter and not for $1800, lol)
My point is, either the dealer has changed position, or it's the fact that the truck has 50,000 miles on it.
A little history:
