rear drive shaft yoke oil leak ?
AfE Year fit Question
06 Megacab Keep Cat and resonator but no Muffler
I have a 04 drw 3500 reg cab 4x4 with a nv 5600 my problem is at my yoke for the rear driveshaft , in the center of the yoke there is a cap and its leaking oil from my transfer case i was wondering if any one has had this problem :confused: and what they did to repair the leak any help would be appreciated
I've had this problem with my 04 and chased this problem for a 100K miles... . finally decided after replacing this seal 3 or 4 times that the seal was getting banged from the end of the drive shaft... . we did 2 things... .
1 - we put an air bag system on the truck so that when we are pulling we can control the road height of the back of the truck..... we tow 20K 95% of the time..... and in doing this we took out a very bad vibration on launch in low and 2nd gear... .
2 - we shortened the drive line about 1/2 to 3/4"... .
We have not had a seal failure... . and have looked at the end of the seal... and no longer see damage from the yoke striking the seal.....
Between the 2..... we've not had a problem..... until we did the above... nothing we could do would stop the oil leak... . the seal leaking is the systom..... not the fault... .
BTW this truck now has almost 200K miles... .
