I just adjusted my rear shoes which has helped my stopping distances a lot. The shoes were not even making contact with the drum. That's how much they needed to be adjusted. Also, my parking brake hasn't worked in some time now. I think these two problems are linked together. I assume since my shoes are not adjusted correctly then there's no way for my p-brake to work. Is that correct? Also, I read somewhere that the rear shoes should slightly drag when you freespin them. What do you say? If so, I need to keep adjusting. I posted this elsewhere but was getting impatient. Thanks Clay
