Changing drums:
Take the hub assembly off the axle- remove the axle shaft, take the retaining nut off (special 2-9/16 socket, or hammer and chisel), slide the hub off.
lay the drum with the lug bolts facing up. Using a drift or block of some sort, punch the lug bolts out, Hub SHOULD come right up and off. This is just a basic run down of how to do it.
Dually spacers:
There are no spacers on the duallies. The offset is built in, so to speak, the designt of the hub and wheels. BUT, if you try to run dual wheels on a SRW pickup axle, you can run into problems with the wheels rubbing the inside of the bed, and having to get new lug bolts and nuts. THe axles are wider on a pickup (vs C&C) dually than a SRW. If you have a flatbed, I see no problem.
I haevnt heard of the rear ends snapping, per se, unless you abuse them. The limited slip clutches go out if you dont keep the fluid changed, and forget the additive, or enough of it. And, the R&P backlash needs to be reset, on averge, every 150-200K. These D70s like to throw shims in a tantrum for not getting fresh fluid often enough.
Daniel
