I took my truck into my dealer for (1) rear end jumping in wet mucky grass while backing my 5th wheel into my yard,& again jumping when going through loose sugar sand,almost getting stuck (2) cracked altenator bracket (3) air conditionining freezing up,& stops blowing untill it thaws, & repeats cycle.
I would appreciate some opinions as to what was told me. The jumping axle(rear end) is normal ,as this is a heavy duty rear end that locks into a solid unit when going through wet grass ,or sand and the wheels are fighting for traction causing the rear end to jump. alternator bracket replaced after a slight discussion of, was the crack just a weld spot,they agreed that it was stamped metal with no welds and replaced it. Air conditioning is again freezing up,& or, not blowing cold,& then blowing cold & freezing up. Has any one had similar a/c problems? Supposedly the replaced the evaporator word, and try again.
Thanks,Pat
Thanks,Pat
