Need some help here. My truck just started making a howling noise in the rear end that resonates through the drive shaft. I haven't dropped the cover yet. Gear lube is due for a change anyway, and I need to install my Mag-Hytec differential cover. I'm thinking it's the pitman bearings. Noise is definitely coming from the rear end, but only under power. If I let off the gas or shift to nuetral it stops. Anything I should be looking for other than normal wear, metal shavings etc. I don't think Dodge is going to warranty this, once they see my truck. Any ideas? Thanks, -Glen
[This message has been edited by Glen Pratt (edited 12-21-2000). ]
