My truck has a whine in the rear end while under load and while the engine holds back. Almost no load at a coast. Oil looks good and no unusual wear.
Could the noise be related to the tightness of the nut on the pinion flange?
About three years ago I removed the pinion flange to replace the seal. Before I took the nut off, I marked it, but I was never able to fully tighten it as much as it was before. Maybe 10 degrees on the turn of the nut shy of what it was.
I'm wondering if that little bit of difference would be enough to allow the pinion gear to change alignment under load to cause the noise? From my recollection, the noise did not start immediately after changing the seal, but not long after that.
It's my 03. 322,000 miles. Thanks!
