rear end oil ?
momentary "blinker" trailer running lights?
Seat covers for a quad cab....
I need to change the oil in my rear end to a synthetic per the owners manual. I want to use Amsoil. What wt. oil, and do I need to use a friction enhancer with Amsoil? How much should I expect to pay for the oil?
I'm running Series 2000 75W-90 AmsOil with oyut limited slip additive and the rear end is working fine. As faras weight goes, how much weight do you tow and what is the climat like where you live/tow to?
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11 all the way forward, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 235/85R16 Goodyears, Dyno'd 342 HP *NRA/USPSA member and proud of it*
Dezrat,
Do a search for every thing you can think of regarding The rear Diff. Such as Dana, Amsoil, Blah, blah, blah. There should be VOLUMES in the archives. Unless our moderaters deleted them all! Diid you?
1997 Cummins Dodge 4x4 Bombed & Amsoiled
Member of TDR,LIC-ROC,GLTDR,NRA
desrat,
I'd suggest draining the axle tubes when you do the changeout. I drained mine all out, then took the floorjack & raised 1 wheel @ a time to drain the axle tubes. You get a bunch out of each side. #ad
Money Sink - 96, 5 speed, Injectors, 280/685 & AFC housing slid.
4" CAT back & CATless, 4" chrome turn down straight out back.
ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Monicas silencer ring removed, Exhaust brake, Mag-Hytec, 3:54, 235s.
HX35s days are numbered, HX40-16 is here.
Un-Bombed = Boring
