Well just got back from Jacksonville. During the last trip from Canada the rear end started howling. After changing the fluid and pulling metal particals off the magnet. The center section was toast. To the sum of $1250. 00. The ring & pinion was ok. Guess I'll change the fluid every 20,000 mile in the future. Best regards, Mike
92 Std cab. LE. 98,000, 5-speed, 3. 54, 105 gal Aux tank in bed. Banks Power pack. 14cm w/wastegate. Pyro & boost guage, oil temp guage. Rebuilt pump turned up, fresh injectors. E-brake. Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. http://hometown. aol.com/hotshothauler/myhomepage/business.html
