REAR END
Suit Accuses DaimlerChrysler of lies
Trying to buy new cummins
MY REAR END SEEMS TO BE LOCKING UP A LITTLE AROUND TURNS. IVE PURCHASED AMSOIL SYN FLUID, DOES THE REAR END COVER NEED A GASGET OR OR JUST THE BLUE GASGET CEMENT. ALSO THE REAR IS LSD, DO I NEED THE ADDITIVE FROM CHRYSLER. IM NOT A GOOD SPELLER.
With the stock cover, just use the silicone sealant, no gasket. I use the Amsoil lube, but I found I needed to use the limited slip additive from Chrysler to keep the clutches happy.
'95 2500 SLT ClubCab, automatic, 3. 54 LSD
Try eating more bran.
Sorry, could'nt resist #ad
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, 16%btdc, yada-yada-yada
www.fostertruck.com/cummins
I would try a bottle of the additive"fish oil" it is pretty cheap and it can't hurt!!
1994 4X4 2500 Auto.
1998 Harley FXDS
1998 Harley Sportster 1200
Just rebuilt the rear differential in my truck, it spun the drivers side main bearing on the differential carrier. It would have helped if the previous owners had serviced it, the pan had not been off. Therefore no change of fluid, ever!! Should change it every 30,000 miles or so, or once a year. I should have changed it when I got the truck but just had not done it yet, probably would not have helped the bearing was too far gone when I got it.
I did it all myself, lot of fun!! except I did have machine shop pull and replace some of the bearings that I could not pull. It cost me just over $200. 00 for the bearings and seals, $50. 00 for tools (2 and 9/16 inch socket for spindle nut). I took Friday 12/1/00 off and worked on it, finished about 6:30pm. Now I am very sore!!!!
I had to grind down the shoulder that the driver's side carrier bearing presses against (by opening to axle tube) as it spun a grove in the seat, I shimed that side for the loss of metal, when I put it back in it was a tight fit but it went in. The differential sounds very good now. Thank God!!
Take this as a testimonial to proper maintenance, oil etc. may cost some but not as much a iron, and labor.
96 CC 4X4 2500 SLT AUTO transmission, PrimeLoc, ISSPRO EGT Boost transmission Temp, GUTTED CAT, 150,000+ Miles still goin' strong, Lots of Ham Radio gear, NO IGNITION NOISE!!! Love my diesel!!!
Caanan,
Off the subject. If you want a spell check, go to your posting as normal and enter you login in and pass word and at the message portion click to get your word, word perfect or what you have as an editor and key your message there and click on edit and then high light the entire message and press cut and then come back to your post message block and click paste. Bingo you message is here and been edited by your word editor for correct spelling.
Note. Cut and paste is done on clicking the right side of the mouse.
Bert
2001,3500 QC 4x4, HO/6spd,bright silver metalic,BD brake.
Caanan,I too am a horrible speller. I write my posts in Outlook Express,free to download from Microsoft,then cut and paste onto the reply page here,fast and easy to do. Only problem is that sometimes my spelling is so far off that the spell checker can't even figure it out.
I just spell it best I can. If you guys don't like my spelling then don't read it. Who am I tryin to impress anyway? #ad
A bottle of the fish oil fixed my speling too. #ad
I love spell-Czech!
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Semi-Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring & muffler stolen.
