I have the 3. 54 rear gear, is it possible to change it to something in the range of 3. 10-3. 20. If not how low can we go?
My shift knob is marked L,1,2,3,H. I hardly ever use L, I was thinking that if you changed the rear gear you would get better fuel mileage and more top speed(most important)
95' 2500 standard trans. 2wd reg cab 125,000 miles.
TST #4 plate kit, 370 Diamond B injectors, Afc spring kit, Gov. spring kit,TST's fuel pressure adapter and 2 guage pillar mount, SPA EGT/Boost guage.
Badly in need of a clutch
Joe D's Sachs is on the way.
