Rear inner fender liners
06 4x4 6 speed dif & transmission fluid capacities
Rear Pin Seal Leaking
Is it best just to get the factory OEM liners (is that even possible?) or is there a good aftermarket brand anyone might suggest. My 01. 5 had them but my 09 came with none.
Will they fit with a B&W turnover ball? You know, the little lever inside the driver side rear fender.
Newt
+1 As well on the liners. Can't believe they don't put them in there (they do now) on a truck as expensive as ours. They really make the back end look finished, No more frame or painted underside of the bed to look at any more. I did them on my last 06 and I did them on my new 06, Takes 4 minutes to do each side..... With the wheels on of course! It keeps all the mud and crud out of the nooks and crannies of the bed sheet metal.
Newt
It will work just fine but you'll need to trim a hole out to have access to the lever. A 3" or 3. 5" hole saw and your good to go. Forgot to mention... . You'll notice a slight drop in road noise and muffler / resonator sound. It's still as loud up front but it seems quieter in the rear when going down the road.
Does anyone know if the rear fender liner will fit a 3500 SRW 2WD. I found some informationonline that leads me to believe that this addition only fits the 2500 not the 3500 SRW but I'm not sure...
I put them on my '03 3500 SRW right after I bought it--agree that they should have been installed by the factory instead of leaving it to the buyer to finish the truck assembly!
I added them to my 03 3500 SRW 4WD as well and like them. Shad
The one thing I do remember is it makes it harder to change the rear shocks with the liners installed.
