2nd Gen Non-Engine/Transmission Rear leaf springs
Engine/Transmission (1998.5 - 2002) 12v or 24v block
Engine/Transmission (1994 - 1998) shimmed the pump plug
So my truck is starting to have the tired look in the rear when it is empty. Can a person just replace the main springs with a little more arch to lift the truck or do you have to repace the full spring pack? When the truck is loaded it sits about the same as others.
Tardog,
Go down to a local spring shop and they can fix things up for you. They can take a look at your spring packs and tell you if the whole pack is bad or if they can be re-arched.
Kevin
