rear light on 3500
Air filter
Tire Pressure for 315-70-17 Tires
on the 3500 dually there is a light in the center of the rear tailgate. do the single wheel 3500's have the light in the middle of the tailgate?
will a 2" leveling kit void warranty? will the 315/70/17's fit without rubbing w/o 2in leveling kit?
There's no rear light onthe SRW's. It's a dually thang.
Yes those tires fit without rubbing if you use the stock wheels. Any wider and you'll need the 2 inches.
Originally posted by Duck
There's no rear light onthe SRW's. It's dually thang.
I wish it was a FORD thing. :mad: That light is so ugly! I have already called my body guy and asked him to get rid of it and the 5 giant holes behind it. :D
Originally posted by CATCRACKER
i like the light. it looks like the cheapest place on the internert for these tires is discounttire.com $600 to my door.
:{ :{ Why can't you live closer! I would trade you gates in a second! :D
Originally posted by Dean Upson
I believe the light is there for DOT regulations. All brands of Dual wheel pickups have them in one form or another.
Dean
Any vehicle over 80" wide is required to have the 3 light bar on the rear of vehicle as well as facing forward. That is also why roof clearance lights are not an option that can be deleted on the 3500's.
I personally like the look of the bar and would consider putting one on my truck if I could find one. I heard that if you buy it from DC you have to buy it in pieces instead of one unit.
The light comes as a unit with the harness attached for around $40. I just ordered one for my louvered tailgate that I use with my fiver.
Dean
It probably looks a little funky on a silver truck, but it blends right in on the Dark Garnet Red :p
Sticks out like a thumb hit with a 3 pound sledge! :-laf
That's an idea, maybe I will just take it off and paint the lens silver and pull the bulbs. Then if the DOT says something it's an easy fix.
There you go :cool:
Louvered Tailgate Marker
Just finished the marker light install on my louvered tailgate. Currently the tailgate is installed on my couch and waiting for spring. :D Using the Dodge parts it just plugs into the existing wiring. Dean, eat your heart out. Casey
[/QUOTE] Sticks out like a thumb hit with a 3 pound sledge!
Must be a different shade of bright silver metallic than mine. Looks great to me ;)
Dean
