hey guys, on the rear gear train ISB engines, there is actually a installation tool that is used to instal the rear main seal, that white plastic ring with a notch cut in it, goes inside this tool, and is what pushes on the seal to set the depth, this ring is never used on our B & ISB front gear train engines. just use that metal depth ring to set the depth of the seal. i would like to point out one thing, there are wear sleeve service kits availiable, a wear sleeve kit inclues a small metal sleeve that gets pressed onto the crankshaft to make a "fresh" surface to seal, sometimes the seals can wear a groove into the crankshaft, and when this happens, the seal will not seal agains the crankshaft, even when new, by putting this sleeve on the end of the crank where the seal is going to be, it creates a new surface to seal against. soo if you doing either a rear main or front crank seal, always check the crank, if you feel a groove in the crank, i would highly reccomend that your use a wear sleeve kit, it most likely will save you from doing the job twice. now the seal that comes in the kit is slightly larger than the stock size seal, that is to compensate for the metal ring that is now on the crankshaft. dont ever try and use a stock size seal with a wear sleeve, it will ruin the seal. there is a special tool, (cummins part # 3824078 for the rear main seal, and the front crank wear sleeve tool part # is 3824500) used to instal these wear sleeve's. the rear wearsleeve kit part number is 3906081, and the front crank wearsleeve kit is part # 3806080. hope this info helps guys!
wes
