Hello First Gen Brothers!
I've been away from the computer for 2 months on vacation in New Zealand with limited TDR access. Withdrawls, I tell you!
I hear from back home that my beloved '92 W250 has eveloped a rear main seal leak. I haven't had the ability to do a "search" for this subject but would appreciate any feedback or help.
Questions: Has anyone in TDR-land had to do a rear main seal replacement? What seal did you use? Is there a prefered replacement seal? If so, part numbers would be appreciated.
Sounds like a great opportunity to install an new clutch while I'm in there!
Thanks for any help in advance... ...
Keeno
1992 W250 5spd. 3. 54 gears, LSD, JRE enhanced VE Injector Pump, BD High Output Injectors, Banks "Stinger Plus" consisting of a replaced 12cm2 wastegated housing, 3 1/2" JRE modified exhaust/muffler, pyro/boost gages, K&N, Skyjacker 2 1/2" front suspension lift to clear 305/70R/16 Goodyear MT's, Mag-Hytec, Amsoil, Rhino liner, Fully Chrominated Aluminum Aftermarket Accessory T-handle Shift Knob
Keeno
