Details here: TDR Privileges
Rotors are pop off. No need to remove any axle like with previous generations. Parking brake shoes are under the rotor. If you have done drum brakes before you will find these easy.
Not on a dually, they are bolted on from the back of the hub. The axle has to be pulled then the hud to remove the rotors. Parking brake is on the hub not the rotor.
