rear rotor help
Price Check for bearings and u-joints
4X4 Dually in the snow
The rotors are slip fit over the wheel studs. Spray with penetrating oil and hit them with a big hammer to break them free from the hub. If you are replacing them you can hit the back side of the rotor face. If not just around the hub, and in between the studs.
As long as it is an SRW they they just pop off with a little whack of the hammer. If it is a DRW then you have to pull the hub and unbolt them first.
